[postgis-devel] Issue 12 in postgis: precision problem in ST_Intersection
codesite-noreply at google.com codesite-noreply at google.com
Mon Jan 12 06:41:37 PST 2009
Comment #2 on issue 12 by christiangda: precision problem in ST_Intersection
http://code.google.com/p/postgis/issues/detail?id=12
   I tried with the new version and got the same result.
SELECT postgis_full_version();
"POSTGIS="1.3.5" GEOS="3.0.3-CAPI-1.4.2" PROJ="Rel. 4.6.1, 21 August 2008"
USE_STATS
(procs from 1.3.4 need upgrade)"
SELECT version();
"PostgreSQL 8.3.5 on x86_64-unknown-linux-gnu, compiled by GCC gcc (GCC)
4.3.0
20080428 (Red Hat 4.3.0-8)"
regards,
Christian
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
