[postgis-devel] Issue 12 in postgis: precision problem in ST_Intersection
codesite-noreply at google.com codesite-noreply at google.com
Mon Jan 12 07:01:14 PST 2009
Comment #3 on issue 12 by robe.... at cityofboston.gov: precision problem in
ST_Intersection
http://code.google.com/p/postgis/issues/detail?id=12
I'm not sure this is fixable isn't this the same issue as was brought up in
this thread
http://postgis.refractions.net/pipermail/postgis-users/2008-December/022277.html
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
