[postgis-devel] GeoJSON failing on 1.4
Obe, Regina robe.dnd at cityofboston.gov
Tue Jan 13 05:33:09 PST 2009
Attached is my diff.  I'm not good at making sense of diffs.  but looks
to me like a bug in our regression test.  i had wiped out my 1.4 svn and
repulled down and compiled.
I'm assuming the diff is telling me that what is expected is
ERROR:  GeoJson: 'Curve' geometry type not supported.
and what is coming back is
ERROR:  GeoJson: 'CircularString' geometry type not supported.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
Courtin Olivier
Sent: Tuesday, January 13, 2009 8:25 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] GeoJSON failing on 1.4
On Jan 13, 2009, at 2:21 PM, Obe, Regina wrote:
Regina,
> I remember the KML failing for me on OpenSUSE, but don't remember the
> geojson failing as well.  Is this normal?
It should not ;)
What kind of failure behaviour do you have ?
Olivier
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
Type: application/octet-stream
Desc: test_34_diff
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090113/d51fed39/attachment.obj>
