[postgis-devel] Issue 94 in postgis: Rename folders/files to be more consistent
codesite-noreply at google.com codesite-noreply at google.com
Thu Jan 15 09:59:18 PST 2009
Comment #5 on issue 94 by mark.cav... at siriusit.co.uk: Rename folders/files
http://code.google.com/p/postgis/issues/detail?id=94
Okay, I've just committed the rename of lwpostgis.sql to postgis.sql, and
the
embedding of the version number in the resulting .so/DLL file. It seems to
work for
me, but let me know if I accidentally broken anything.
Next, I'll come along and rename the lwgeom/ directory to postgis.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
