[postgis-devel] Alignment Revision
    strk
    strk at keybit.net
    Wed Jan 21 04:29:40 PST 2009
On Wed, Jan 21, 2009 at 11:37:53AM +0000, Mark Cave-Ayland wrote:
> Yes. Please see my original post and test harness here:
> http://lists.refractions.net/pipermail/postgis-devel/2009-January/004473.html.
>  Even with a memcpy() from unaligned to aligned space, the speed difference
> is quite impressive.
I suggest you add a test using getPoint_internal on unaligned
memory. The rational here is that IFF the architecture doesn't
required aligned memory, we might still use getPoint_internal
in there w/out changing the structure (and possibly with not-so-big
overhead due to non-aligned reads).
In other words, I'm not convinced that the performance penalty
comes from aligned vs. unaligned, but mostly from the additional
function calls (memcpy) required at each iteration.
> It may be worth you playing with the testmem.c harness in the above
> email to see whether it has a similar performance effect when accessing
> rasters.
I guess it really depends on use cases, the accesses could
be optimized based on the operation. For example, if the
function only needs to return a given point (say pointN)
a single memcpy (per value) won't be a big problem, while if
it needs to scan the whole thing a single memcpy (per pointarray)
might not be a big problem.
--strk;
 Free GIS & Flash consultant/developer      ()  ASCII Ribbon Campaign
 http://foo.keybit.net/~strk/services.html  /\  Keep it simple!
