[postgis-devel] Another Data Point
David William Bitner david.bitner at gmail.com
Wed Jan 21 10:18:10 PST 2009
Would any of the 8.4 implementation of the generic array_agg() function be
applicable to this?
On Wed, Jan 21, 2009 at 11:10 AM, Obe, Regina <robe.dnd at cityofboston.gov>wrote:
> That is not surprising.  I think much of the benefit of my code was
> spoon feeding to postgis so sort of acting as a memory manager within
> the PostgreSQL context and my arrays were much smaller -- never ended up
> with a single array of yeh big as I recall.  Though its been a while
> since I have looked.
> Anyrate I'll retest in the next day or so against 3.1.   I would be
> curious to see the results.
> Yes accumulation when you get in the 1000s is non-trivial because
> PostgreSQL has to resize the array.
> Which is why a construct such as
> ARRAY(SELECT the_geom FROM sometable)
> is faster than
> SELECT ST_Accum(the_geom)
> FROM sometable
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
> Ramsey
> Sent: Wednesday, January 21, 2009 12:05 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] Another Data Point
> Interesting! The Shark only samples for about 20 seconds, so I only
> got the first 10% or so of the run, and the biggest user in that time
> period memcpy'ing in LWGEOM_accum (postgis) and
> advance_transition_function (pgsql). So we are spending a non-trivial
> amount of time just accumulating the input...
> P
> On Wed, Jan 21, 2009 at 9:00 AM, Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
> > The glove is dropped indeed... why speculate when I have the Shark...
> > time to see where our time goes...
> > P
> > On Wed, Jan 21, 2009 at 8:55 AM, Martin Davis
> <mbdavis at refractions.net> wrote:
> >> Go for it, Regina!  The glove is dropped...
> >> Although I suspect this test may simply be running into the slower
> memory
> >> performance due to any or all of Postgres, C, GEOS compared to good
> ol'
> >> Java...  Hard to beat that tuned JVM memory manager!
> >> Obe, Regina wrote:
> >>> Ah I think JTS was able to do this in about 40-50 seconds.  And my
> >>> version was able to beat out Kevin's nested by a small margin.  I'll
> >>> retest on mine.
> >>> So I think we still need work here.
> >>> I'm curious what would happen if I combined the algorithm I wrote
> with
> >>> the new ST_Union how things would fair.  In theory it should fair
> the
> >>> same, but I'm not really using Martin's cascaded union algorithm to
> the
> >>> letter.
> Paul
> >>> Ramsey
> >>> Sent: Wednesday, January 21, 2009 12:50 AM
> >>> Cc: lee.keel at uai.com
> >>> Subject: [postgis-devel] Another Data Point
> >>> Using the original sample set from Lee Keel,
> >>> With the old style ST_Union, 3 hours, 27 minutes:
> >>> uniontest=# select st_area(st_union(the_geom)) from sample_poly;
> >>>      st_area
> >>>  0.0324039850011104
> >>> (1 row)
> >>> Time: 12419261.819 ms
> >>> With the new cascaded ST_Union, 4 minutes, 30 seconds, or 46 times
> >>> faster.
> >>> uniontest=# select st_area(st_union_fast(the_geom)) from
> sample_poly;
> >>>      st_area
> >>>  0.0324039850054305
> >>> (1 row)
> >>> Time: 271618.181 ms
> >>> That's one nasty data set.
> >>> P.
> >>> _______________________________________________
> >>> postgis-devel mailing list
> >>> postgis-devel at postgis.refractions.net
> >>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> >>> The substance of this message, including any attachments, may be
> >>> confidential, legally privileged and/or exempt from disclosure
> >>> pursuant to Massachusetts law. It is intended
> >>> solely for the addressee. If you received this in error, please
> >>> contact the sender and delete the material from any computer.
> >> Martin Davis
> >> Senior Technical Architect
> >> Refractions Research, Inc.
> >> (250) 383-3022
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090121/4a4595bb/attachment.html>
