[postgis-devel] Another Data Point
Paul Ramsey pramsey at cleverelephant.ca
Wed Jan 21 10:58:41 PST 2009
Well, just running this:
uniontest=# select geometrytype(collect(the_geom)) from sample_poly;
  geometrytype
 GEOMETRYCOLLECTION
(1 row)
Time: 261624.195 ms
takes 251 of the 271 seconds the union operation took... the
implication is that the GEOS portion of the work is on the order of 10
seconds.
P.
On Wed, Jan 21, 2009 at 10:10 AM, Martin Davis <mbdavis at refractions.net> wrote:
> Could be...   It would be interesting to see whether GEOS is faster than
> JTS.   Needs a test environment able to run both pieces of code on the same
> hardware.
> Paul Ramsey wrote:
>> I got another run in, right near the end, and it showed that
>> GEOSUnionCascaded took only about 50% of the time in that slice. There
>> was still more memcpy'ing first. I bet GEOSUnionCascaded on its own
>> would be as fast as JTS (or faster?).
>> P.
>> On Wed, Jan 21, 2009 at 9:05 AM, Paul Ramsey <pramsey at cleverelephant.ca>
>> wrote:
>>> Interesting! The Shark only samples for about 20 seconds, so I only
>>> got the first 10% or so of the run, and the biggest user in that time
>>> period memcpy'ing in LWGEOM_accum (postgis) and
>>> advance_transition_function (pgsql). So we are spending a non-trivial
>>> amount of time just accumulating the input...
>>> P
>>> On Wed, Jan 21, 2009 at 9:00 AM, Paul Ramsey <pramsey at cleverelephant.ca>
>>> wrote:
>>>> The glove is dropped indeed... why speculate when I have the Shark...
>>>> time to see where our time goes...
>>>> P
>>>> On Wed, Jan 21, 2009 at 8:55 AM, Martin Davis <mbdavis at refractions.net>
>>>> wrote:
>>>>> Go for it, Regina!  The glove is dropped...
>>>>> Although I suspect this test may simply be running into the slower
>>>>> memory
>>>>> performance due to any or all of Postgres, C, GEOS compared to good ol'
>>>>> Java...  Hard to beat that tuned JVM memory manager!
>>>>> Obe, Regina wrote:
>>>>>> Ah I think JTS was able to do this in about 40-50 seconds.  And my
>>>>>> version was able to beat out Kevin's nested by a small margin.  I'll
>>>>>> retest on mine.
>>>>>> So I think we still need work here.
>>>>>> I'm curious what would happen if I combined the algorithm I wrote with
>>>>>> the new ST_Union how things would fair.  In theory it should fair the
>>>>>> same, but I'm not really using Martin's cascaded union algorithm to
>>>>>> the
>>>>>> letter.
>>>>>> -----Original Message-----
>>>>>> From: postgis-devel-bounces at postgis.refractions.net
>>>>>> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
>>>>>> Paul
>>>>>> Ramsey
>>>>>> Sent: Wednesday, January 21, 2009 12:50 AM
>>>>>> To: PostGIS Development Discussion
>>>>>> Cc: lee.keel at uai.com
>>>>>> Subject: [postgis-devel] Another Data Point
>>>>>> Using the original sample set from Lee Keel,
>>>>>> With the old style ST_Union, 3 hours, 27 minutes:
>>>>>> uniontest=# select st_area(st_union(the_geom)) from sample_poly;
>>>>>>     st_area
>>>>>>  0.0324039850011104
>>>>>> (1 row)
>>>>>> Time: 12419261.819 ms
>>>>>> With the new cascaded ST_Union, 4 minutes, 30 seconds, or 46 times
>>>>>> faster.
>>>>>> uniontest=# select st_area(st_union_fast(the_geom)) from sample_poly;
>>>>>>     st_area
>>>>>>  0.0324039850054305
>>>>>> (1 row)
>>>>>> Time: 271618.181 ms
>>>>>> That's one nasty data set.
>>>>>> P.
>>>>>> _______________________________________________
>>>>>> postgis-devel mailing list
>>>>>> postgis-devel at postgis.refractions.net
>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>>>>>> The substance of this message, including any attachments, may be
>>>>>> confidential, legally privileged and/or exempt from disclosure
>>>>>> pursuant to Massachusetts law. It is intended
>>>>>> solely for the addressee. If you received this in error, please
>>>>>> contact the sender and delete the material from any computer.
>>>>> Martin Davis
>>>>> Senior Technical Architect
>>>>> Refractions Research, Inc.
>>>>> (250) 383-3022
> Martin Davis
> (250) 383-3022
