[postgis-devel] Compile issues on MingW trunk
Obe, Regina robe.dnd at cityofboston.gov
Fri Jan 23 07:26:33 PST 2009
I tried doing a make clean and
sh autogen.sh
on MingW and I'm getting this on autogen and not sure what it means
/usr/share/aclocal/autoopts.m4:22: warning: underquoted definition of
AG_PATH_AUTOOPTS
  run info '(automake)Extending aclocal'
  or see
http://sources.redhat.com/automake/automake.html#Extending%20aclocal
Can't locate object method "path" via package "Request" (perhaps you
forgot to load "Request"?) at /usr/share/autoconf/Autom4te/C4che.pm line
69, <GEN1> line 111.
aclocal: autom4te failed with exit status: 127
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
