[postgis-devel] Deprecation Warnings
Obe, Regina robe.dnd at cityofboston.gov
Fri Jan 23 14:25:23 PST 2009
Hmm although it really wouldn't be deprecate -- it would be lets remove them and allow people to reinstate them if they want as Kevin suggested.
Personally I don't care for warnings -- either keep it or get rid of it.  Warnings sounds like a lot of wasted log space which will probably only be seen by logs and potentially mysteriously slow down applications in the process.
Though I guess we must think of the children (Mapserver, GeoServer and ZigGIS and so forth which may be using the old names).  But then I suppose anyone using apps relying on deprecated names would just install the wrapper patch.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Obe, Regina
Sent: Fri 1/23/2009 5:06 PM
To: PostGIS Development Discussion
Subject: RE: [postgis-devel] Deprecation Warnings
+2
From: postgis-devel-bounces at postgis.refractions.net on behalf of David William Bitner
Sent: Fri 1/23/2009 4:51 PM
Subject: Re: [postgis-devel] Deprecation Warnings
+1, I like Cake.
On Fri, Jan 23, 2009 at 2:59 PM, Kevin Neufeld <kneufeld at refractions.net>wrote:
> What if we deprecate the functions as you suggest (and eventually remove
> them), but provide a sql script that will reinstate them as wrappers to the
> ST_* methods.  That way, folks can have their cake and eat it too ...
> upgrade to the latest version without breaking their apps.
> -- Kevin
> Paul Ramsey wrote:
>> Could we use the function creation option
>> SET configuration_parameter { TO value | = value | FROM CURRENT }
>> to, for example, set postgis_deprecated to true?
>> Then in the function, we could warn on deprecation. So the same
>> backend to intersects() could be used by several function names, but
>> only some would raise deprecation warnings.
>> Or do we want to continue our gentle regime of letting the old names
>> live in quite obscurity?
>> P.
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090123/a4a0b3c4/attachment.html>
