[postgis-devel] Issue 105 in postgis: pgsql2shp seems to produce incorrect dbase files, problems importing into Gnumeric
codesite-noreply at google.com codesite-noreply at google.com
Mon Jan 26 01:15:18 PST 2009
Status: New
Owner: ----
New issue 105 by phopfgartner: pgsql2shp seems to produce incorrect dbase
http://code.google.com/p/postgis/issues/detail?id=105
What steps will reproduce the problem?
1. Export data with shp2pgsql
2. Import the generated dbase file into Gnumeric
Gnumeric does not show the last record.
Problem analysis by Gnumeric developers suggests 2 problems with the
generated file, major details at
http://bugzilla.gnome.org/show_bug.cgi?id=568454.
PostgreSQL: 8.2.9, as in current CentOS Testing repository
PostGIS: 1.3.5
	P200101.dbf  8.1 KB
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
