[postgis-devel] Issue 106 in postgis: pgsql2shp memory leak on WIndows
codesite-noreply at google.com codesite-noreply at google.com
Thu Jan 29 15:42:35 PST 2009
Comment #2 on issue 106 by krellor: pgsql2shp memory leak on WIndows
http://code.google.com/p/postgis/issues/detail?id=106
I have downloaded your compiled exe and will try again this evening and see
if it
still throwing heap corruptions or not.  I will also test the projection
file and
make sure it reads properly.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
