[postgis-devel] [PostGIS] #212: compound curve in a curve polygon is flaky
PostGIS trac at osgeo.org
Wed Jul 1 04:20:08 PDT 2009
  Reporter:  robe     |       Owner:  mleslie
      Type:  defect   |      Status:  reopened
  Priority:  medium   |   Milestone:  postgis 1.4.0
 Component:  postgis  |     Version:  1.4
Resolution:           |    Keywords:
Comment (by mcayland):
 If it helps, I remember I found a couple of typos in the curve support a
 while back related to number of points. The minimum number of points in a
 curve should be 3, however in some places the check was incorrectly coded
 as 4 :(
 If you add a 4th point to your example, does it then work?
 ATB,
 Mark.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/212#comment:6>
