[postgis-devel] PostGIS Windows installer source/repository
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Fri Jul 3 02:24:47 PDT 2009
Picavet Vincent wrote:
> Hello,
> I managed to compile PostGIS and its windows installer thanks to
> http://trac.osgeo.org/postgis/wiki/UsersWikiWinCompile
> and with the PostGIS windows installer from
> http://postgis.refractions.net/download/windows/
> ( or http://pgfoundry.org/projects/stackbuilder/ ).
> The Windows installer sources seem to be available only for PostGIS
> 1.3.6 as a source tar.gz.
> Is there a svn/cvs repository of the PostGIS installer source code
> somewhere ?
Not at the moment as not that many people have been able to build the
Windows version; hopefully this will change in future, and we could
reconsider if it becomes necessary.
> I would like to recompile 1.4 and 1.5SVN versions as well, is there a
> version of the installer for these versions ?
Not yet. although it should be reasonably simple to make the required
changes to the paths/files to make sure everything is included.
> Thanks a lot by the way for the wiki page and the installer. Building on
> Windows can be quite complicated, but with explanations and a magic
> installer tool it works like a charm.
No worries. I think possibly Regina did most of the work on this?
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
