[postgis-devel] Problem compiling with MinGW from SVN
strk strk at keybit.net
Mon Jul 6 08:52:38 PDT 2009
Nicklas,
Please try the attached patch, it uses the non-reentrant version
and manual scans for the inner loop. We shouldn't really need
reentrancy in postgis ...
--strk;
 Free GIS & Flash consultant/developer      ()  ASCII Ribbon Campaign
 http://foo.keybit.net/~strk/services.html  /\  Keep it simple!
On Sun, Jul 05, 2009 at 02:32:54PM +0200, strk wrote:
> On Sun, Jul 05, 2009 at 12:35:25PM +0200, nicklas.aven at jordogskog.no wrote:
> > Hallo
> > I tried to compile from SVN wich has worked great before. I think the problem is strtok_r() used in lwgeom_geos, that is supposed to be found in string.h as I understand it. In my version in MinGW there is no strtok_r() in string.h, but strtok(). Is it a problem of versions or?
> According to my manual page, strtok_r is compatible with POSIX.1-2001.
> The non _r version is not reentrant, if other developers are fine with
> that I could change to use it.
Index: postgis/lwgeom_geos.c
--- postgis/lwgeom_geos.c	(revision 4261)
+++ postgis/lwgeom_geos.c	(working copy)
@@ -862,7 +862,6 @@
 	int joinStyle  = DEFAULT_JOIN_STYLE;
 	char *param;
 	char *params = NULL;
-	char *saveptr = NULL;
 	PROFSTART(PROF_QRUN);
@@ -887,24 +886,21 @@
 		for (param=params; ; param=NULL)
-			char *saveptr2, *key, *val;
-			param = strtok_r(param, " ", &saveptr);
+			char *key, *val;
+			param = strtok(param, " ");
 			if ( param == NULL ) break;
-			/* lwnotice("Param: %s", param); */
+			POSTGIS_DEBUGF(3, "Param: %s", param);
-			key = strtok_r(param, "=", &saveptr2);
-			if ( key == NULL ) {
-				lwerror("Malformed buffer parameter");
-				break;
-			val = strtok_r(NULL, "=", &saveptr2);
-			if ( val == NULL ) {
+			key = param;
+			val = strchr(key, '=');
+			if ( val == NULL || *(val+1) == '\0' ) {
 				lwerror("Missing value for buffer "
 				        "parameter %s", key);
 				break;
+			*val = '\0'; ++val;
-			/* lwnotice("Param: %s : %s", key, val); */
+			POSTGIS_DEBUGF(3, "Param: %s : %s", key, val);
 			if ( !strcmp(key, "endcap") )
@@ -926,7 +922,7 @@
 				else
 					lwerror("Invalid buffer end cap "
-					        "style: %s (accept "
+					        "style: %s (accept: "
 					        "'round', 'flat' or 'square'"
 					        ")", val);
 					break;
@@ -950,7 +946,7 @@
 				else
 					        "'round', 'mitre' or 'bevel'"
 					        ")", val);
 					break;
@@ -968,7 +964,7 @@
 			else
-				lwerror("Invalid buffer parameter: %s (accept"
+				lwerror("Invalid buffer parameter: %s (accept: "
 				        "'endcap', 'join', 'mitre_limit' and "
 				        "'quad_segs')", key);
 				break;
