[postgis-devel] [PostGIS] #183: ST_LineToCurve gives getPoint4d_p offset error
PostGIS trac at osgeo.org
Tue Jul 7 05:04:23 PDT 2009
  Reporter:  robe     |       Owner:  robe
      Type:  defect   |      Status:  assigned
  Priority:  low      |   Milestone:  postgis 1.3.7
 Component:  postgis  |     Version:  1.4
Resolution:           |    Keywords:
Changes (by robe):
  * milestone:  postgis 1.4.1 => postgis 1.3.7
Comment:
 This does the same for 1.3 so we need to backpatch to 1.3 to close this
 out.  I'm personally of the opinion that if we are going to be fixing bugs
 that exist in 1.3 as  we should do it at the same time as we patch 1.3 and
 that we should be foxusing on bugs introduced in 1.4 (this is a long
 standing one).  Which is why I really am not in a rush to fix this right
 now.
 SELECT
 ST_LineToCurve(ST_LineMerge(ST_Collect(ST_CurveToLine(ST_GeomFromEWKT('CIRCULARSTRING(0
 0, 1 1, 1 0)')),
 ST_GeomFromEWKT('LINESTRING(1 0, 0 1)') ))) ;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/183#comment:7>
