[postgis-devel] [PostGIS] #180: History table example implementation
PostGIS trac at osgeo.org
Tue Jul 7 07:22:22 PDT 2009
  Reporter:  pramsey      |       Owner:  pimpaa
      Type:  enhancement  |      Status:  assigned
  Priority:  medium       |   Milestone:  postgis 1.5.0
 Component:  postgis      |     Version:
Resolution:               |    Keywords:
Comment (by pimpaa):
 Hello everyone,
 I´ve came up with a solution for this ticket, altought there is room for
 improvent.
 How this works?
 Execute the SQL files in any PostGIS database.
 It will create the table historic_information on the public schema (need
 direction with this).
 execute the following sp to create a historic table of any type of
 geometry:
 select
 create_history_table(schema,table_to_log,primary_field,geometry_field,geometry_type,ndims,SRID);
 this will create the table foo_history on the same schema as the original
 table. i will create all the rules necessary to log the updates, inserts
 and deletes to the original table.
 in the history table we have a current version field, which will log which
 is the ID of the current version of that feature.
 I did not tested it out extensively.
 Thanks for all the help, and please give the usual comment and critics.
 George
Ticket URL: <http://trac.osgeo.org/postgis/ticket/180#comment:7>
