[postgis-devel] st_dwithin, st_within, st_dcompletlywithin
nicklas.aven at jordogskog.no nicklas.aven at jordogskog.no
Thu Jul 9 05:32:48 PDT 2009
I have been looking some more on this Hausdorff Distance. I'm afraid I have to take a step back. There are aspects that is not handled by my original idea and I can't see how to deal with it. The problem I didn't realize is that if the second geometry is "surrounding" the first, we have to search for the most far away point between the vertices. In the ordinary maxdistance-case we don't have to consider that and the maxdistance is always between two vertices.  /Nicklas
2009-07-09 Paragon Corporation wrote:
Oh that's what that is. Hmm and I think its already ported to PostGIS,
>though would be interesting to compare the speeds and results. Since the
>current one in trunk is a GEOS call and Nicklas' would be a native PostGIS.
>http://trac.osgeo.org/postgis/ticket/209
>Paul are you hmm planning add this to the manual -- I see you closed it? I
>don't recall seeing it in the 1.5 docs or were we waiting for GEOS to be
>patched first?
>Thanks,
>Regina
>-----Original Message-----
>From: postgis-devel-bounces at postgis.refractions.net
>[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Martin
>Davis
>Sent: Wednesday, July 08, 2009 6:14 PM
>To: PostGIS Development Discussion
>Subject: Re: [postgis-devel] st_dwithin, st_within, st_dcompletlywithin
>That distance metric is known as the Hausdorff Distance. It's implemented
>in JTS, and probably in GEOS as well.
>nicklas.aven at jordogskog.no wrote:
>> A function that gives the answer to for example:
>> "How far away from France can you get in Belgia"
>> To answer that we have to store compare the shortest distance to
>> geometry2 from each vertex in geometry1 and finaly find wich vertex in
>> geometry1 that has the highest "mindistance" to geometry2.
>> Hope the idee is possible to understand. Is it of any use?
>Martin Davis
>Senior Technical Architect
>Refractions Research, Inc.
>(250) 383-3022
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090709/63892aaa/attachment.html>
