[postgis-devel] problem with makefile in MinGW in trunk
nicklas.aven at jordogskog.no nicklas.aven at jordogskog.no
Mon Jul 13 04:01:16 PDT 2009
Then it seems to give exactly the same error-messages as in branch 1.4    is it something strange with my mingw-installation or is it the same thing for you Regina?or anyone else compiling with MinGW /Nicklas
2009-07-13 Mark Cave-Ayland wrote:
nicklas.aven at jordogskog.no wrote:
>> I downloaded 1.4 branch and tested.
>> "make clean" gives exactly the same error as the trunk
>> "make check" gives this after a successfull cunit-test:
>> make -C regress check
>> make[1]: Entering directory `/c/thesrc/pg14/regress'
>> make -C ../postgis
>> make[1]: make: Command not found
>> make[1]: *** [../postgis/postgis.so] Error 127
>> make[1]: Leaving directory `/c/thesrc/pg14/regress'
>> make: *** [check] Error 2
>Hmmm if you revert r4134 from trunk, does that fix the issue? You might
>need to do some experimentation with "make" to find exactly what is
>happening to PATH before and after those lines in trunk...
>ATB,
>Mark.
>Mark Cave-Ayland - Senior Technical Architect
>PostgreSQL - PostGIS
>Sirius Corporation plc - control through freedom
>http://www.siriusit.co.uk
>t: +44 870 608 0063
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090713/72b6c27b/attachment.html>
