[postgis-devel] why this difference when sub-query
Tom Lane tgl at sss.pgh.pa.us
Mon Jul 13 11:02:23 PDT 2009
nicklas.aven at jordogskog.no writes:
> if I run:
> select st_astext(geom1) from
> (select NULL as geom1) a;
> I get:
> FEIL:  failed to find conversion function from unknown to geometry
The reason for that is that the output column types of the sub-query
have to be identified, and since there is no available information
about the type of the NULL, it gets marked as "unknown", which is a
type that has no operations.  Then the outer query needs to convert
to geometry to feed the function, and there isn't a conversion to
do that.  You could write something like
	(select NULL::geometry as geom1) a;
to avoid this.
As an aside, I believe that the SQL standard doesn't allow a bare NULL
like that at all -- per spec, you are *always* required to cast it to
some identifiable type immediately.  Postgres and most other SQL
implementations are a bit laxer, but you can still run into trouble
if there isn't some pretty-nearby context that determines what type
the NULL constant should be considered to be.  For PG, "nearby"
generally means "inside the same subquery".
			regards, tom lane
