[postgis-devel] problem with makefile in MinGW in trunk
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Mon Jul 13 13:09:33 PDT 2009
nicklas.aven at jordogskog.no wrote:
> yes, exactly the same as me.
> But this is a new fenomena. Not very long time ago it worked fine,
> butnow both the trunk and 1.4 branch gives the same error.
> I found an old makefile (in regression folder) from a few months ago and
> commented some rows that differed from the old one, as described earlier
> in this thread and then "make clean" worked again. But make check still
> didn't work. I don't know if there is anything in common between the
> errors, but in both cases it is screaming after commands that should be
> available.
> /Nicklas
After a bit of a play on my Win32 virtual, it looks like the ":" in the
PGSQL_BINDIR variable is causing the PATH processor to choke. The
attached patch seems to fix things for me - can you please test?
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Type: text/x-diff
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090713/e76e9ac5/attachment.patch>
