[postgis-devel] 1.4.0 Could it be True
Greg Troxel gdt at ir.bbn.com
Mon Jul 13 14:17:39 PDT 2009
I am upgrading the pkgsrc entry for postgis and finding the following
differences from 1.3.5.  Are these all expected?  (PLIST is pkgsrc's
list of the files the package is supposed to install, in this case tuned
against what 1.3.5 does.)
=> Checking file-check results for postgresql82-postgis-1.4.0rc2
ERROR: ************************************************************
ERROR: The following files are in the PLIST but not in /usr/pkg:
ERROR:         /usr/pkg/lib/liblwgeom.so
ERROR:         /usr/pkg/lib/liblwgeom.so.1
ERROR:         /usr/pkg/lib/liblwgeom.so.1.3
ERROR:         /usr/pkg/share/doc/postgis/long_xact.xml
ERROR:         /usr/pkg/share/postgresql/contrib/lwpostgis.sql
ERROR:         /usr/pkg/share/postgresql/contrib/lwpostgis_upgrade.sql
ERROR: The following files are in /usr/pkg but not in the PLIST:
ERROR:         /usr/pkg/lib/postgresql/libpostgis-1.4.a
ERROR:         /usr/pkg/lib/postgresql/libpostgis-1.4.la
ERROR:         /usr/pkg/lib/postgresql/libpostgis-1.4.so
ERROR:         /usr/pkg/lib/postgresql/libpostgis-1.4.so.0
ERROR:         /usr/pkg/lib/postgresql/libpostgis-1.4.so.0.0.0
ERROR:         /usr/pkg/share/doc/postgis/faq.xml
ERROR:         /usr/pkg/share/doc/postgis/installation.xml
ERROR:         /usr/pkg/share/doc/postgis/introduction.xml
ERROR:         /usr/pkg/share/doc/postgis/performance_tips.xml
ERROR:         /usr/pkg/share/doc/postgis/reference.xml
ERROR:         /usr/pkg/share/doc/postgis/reference_old.xml
ERROR:         /usr/pkg/share/doc/postgis/release_notes.xml
ERROR:         /usr/pkg/share/doc/postgis/reporting.xml
ERROR:         /usr/pkg/share/doc/postgis/template.xml
ERROR:         /usr/pkg/share/doc/postgis/using_postgis_app.xml
ERROR:         /usr/pkg/share/doc/postgis/using_postgis_dataman.xml
ERROR:         /usr/pkg/share/postgresql/contrib/postgis.sql
ERROR:         /usr/pkg/share/postgresql/contrib/postgis_upgrade.sql
ERROR:         /usr/pkg/share/postgresql/contrib/uninstall_postgis.sql
(I'm also having some minor packaging issues about $libdir substitution
in the loader script, so I can't report on how gmake check does yet.)
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090713/29bcac1d/attachment.sig>
