[postgis-devel] problem with makefile in MinGW in trunk
nicklas.aven at jordogskog.no nicklas.aven at jordogskog.no
Fri Jul 17 00:45:22 PDT 2009
It still won't work for me. But one difference, the compiler returns the linenumber with error :-) now it looks like this: make -C regress check
make[1]: Entering directory `/c/thesrc/pg15/regress'
sed 's,$libdir/postgis,/c/thesrc/pg15/regress/../postgis/libpostgis,g' ../postgis/postgis.sql > postgis.sql
./run_test: line 386: psql: command not found
Creating spatial db postgis_reg
./run_test: line 393: createdb: command not found
./run_test: line 394: createlang: command not found
./run_test: line 413: psql: command not found Something went wrong (no postgis installed in postgis_reg).
 For details, check /tmp/pgis_reg_5252/regress_logmake[1]: *** [check] Error 1
make[1]: Leaving directory `/c/thesrc/pg15/regress'
make: *** [check] Error 2
/Nicklas
2009-07-16 Mark Cave-Ayland wrote:
nicklas.aven at jordogskog.no wrote:
>> Yes, the patch helped "make clean", but "make check" still gives:
>> make[1]: Leaving directory `/c/thesrc/pg15/liblwgeom/cunit'
>> ./run_test: psql: command not found
>> ./run_test: createdb: command not found
>> ./run_test: createlang: command not found
>> For details, check /tmp/pgis_reg_4372/regress_log
>> Thanks
>> Nicklas
>Okay - please try the attached. This seems to get regression tests
>working for me, but pgsql2shp/shp2pgsql seem to give multiple WKB
>regression failures :(
>Can anyone else confirm?
>ATB,
>Mark.
>Mark Cave-Ayland - Senior Technical Architect
>PostgreSQL - PostGIS
>Sirius Corporation plc - control through freedom
>http://www.siriusit.co.uk
>t: +44 870 608 0063
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090717/375686d0/attachment.html>
