[postgis-devel] problem with makefile in MinGW in trunk
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Fri Jul 17 03:15:38 PDT 2009
nicklas.aven at jordogskog.no wrote:
> yes, I think I did
> and now I downloaded the trunk agin,
> applied the patced
> and ran:
> autogen.sh
> configure --prefix=/c/postgres84
> --with-pgconfig=/c/postgres84/bin/pg_config
> -with-geosconfig=/c/postgres84/bin/geos-config --with-projdir=/c/proj4
> && make && make install
> and then:
> make check
> but I still get the same errors.
> I don't have proj4 in the postgres-tree as you see, but that shouldn't
> matter?
> /Nicklas
Yeah, that shouldn't affect the PATH at all :(  Can you post the
contents of regress/Makefile?
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
