[postgis-devel] problem with makefile in MinGW in trunk
nicklas.aven at jordogskog.no nicklas.aven at jordogskog.no
Fri Jul 17 04:02:00 PDT 2009
now something happened (your first alternative) and the answer is: make -C regress check
make[1]: Entering directory `/c/thesrc/pg15_ny/regress'
sed 's,$libdir/postgis,/c/thesrc/pg15_ny/regress/../postgis/libpostgis,g' ../postgis/postgis.sql > postgis.sql
echo /c/POSTGR~3/bin /c/thesrc/pg15_ny/regress /c/POSTGR~3/bin /c/thesrc/pg15_ny/regress
./run_test: line 386: psql: command not found
Creating spatial db postgis_reg
./run_test: line 393: createdb: command not found
./run_test: line 394: createlang: command not found
./run_test: line 413: psql: command not found Something went wrong (no postgis installed in postgis_reg).
 For details, check /tmp/pgis_reg_5864/regress_logmake[1]: *** [check] Error 1
make[1]: Leaving directory `/c/thesrc/pg15_ny/regress'
make: *** [check] Error 2
 should the same thing be repeated like that in the path?
and why is opstgres in uppercase. the name of the folder is c:\postgres84 /Nicklas
2009-07-17 Mark Cave-Ayland wrote:
nicklas.aven at jordogskog.no wrote:
>> it didn't like it
>Okay. Change:
>echo $(PATH)
>to:
>echo $(PGSQL_BINDIR)
>and see what happens. If that doesn't work, you can also try changing:
>PATH := "$(PGSQL_BINDIR):$(PATH)"
>to:
>PATH := "$(PGSQL_BINDIR)":$(PATH)
>ATB.
>Mark.
>Mark Cave-Ayland - Senior Technical Architect
>PostgreSQL - PostGIS
>Sirius Corporation plc - control through freedom
>http://www.siriusit.co.uk
>t: +44 870 608 0063
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090717/ed5faf62/attachment.html>
