[postgis-devel] problem with makefile in MinGW in trunk
nicklas.aven at jordogskog.no nicklas.aven at jordogskog.no
Fri Jul 17 04:10:09 PDT 2009
it returned: PATH=.:/usr/local/bin:/mingw/bin:/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem:/c/Programfiler/Hewlett-Packard/IAM/bin:/c/Programfiler/Windows Imaging/:/c/WINDOWS/system32/WindowsPowerShell/v1.0:/mingw/bin:/c/Programfiler/Microsoft SQL Server/100/Tools/Binn/:/c/Programfiler/Microsoft SQL Server/100/DTS/Binn/:/c/Programfiler/Microsoft SQL Server/100/Tools/Binn/VSShell/Common7/IDE/:/c/Programfiler/TortoiseSVN/bin:/c/strawberry/c/bin:/c/strawberry/perl/bin
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PSC1
PYTHONPATH=C:\Programfiler\ArcGIS\bin
PKG_CONFIG_PATH=/mingw/lib/pkgconfig
2009-07-17 Mark Cave-Ayland wrote:
nicklas.aven at jordogskog.no wrote:
>> now something happened (your first alternative)
>> and the answer is:
>> make -C regress check
>> make[1]: Entering directory `/c/thesrc/pg15_ny/regress'
>> sed
>> 's,$libdir/postgis,/c/thesrc/pg15_ny/regress/../postgis/libpostgis,g'
>> ../postgis/postgis.sql > postgis.sql
>> echo /c/POSTGR~3/bin /c/thesrc/pg15_ny/regress /c/POSTGR~3/bin
>> ./run_test: line 386: psql: command not found
>> Creating spatial db postgis_reg
>> ./run_test: line 393: createdb: command not found
>> ./run_test: line 394: createlang: command not found
>> ./run_test: line 413: psql: command not found
>> Something went wrong (no postgis installed in postgis_reg).
>> For details, check /tmp/pgis_reg_5864/regress_log
>> make[1]: *** [check] Error 1
>> make[1]: Leaving directory `/c/thesrc/pg15_ny/regress'
>> make: *** [check] Error 2
>> should the same thing be repeated like that in the path?
>> and why is opstgres in uppercase. the name of the folder is
>> c:\postgres84
>> /Nicklas
>That's really weird - what does a plain "env | grep PATH" return in an
>MSYS session? For some reason, your individual paths above are separated
>by spaces - they need to be separated by colons, as per Unix, e.g.
>echo $PATH
>/usr/local/bin:.:/path/to/postgres
>Don't worry about the short folder names - these are internal Windows
>names for folders on filesystems that can't/won't support long filenames.
>ATB,
>Mark.
>Mark Cave-Ayland - Senior Technical Architect
>PostgreSQL - PostGIS
>Sirius Corporation plc - control through freedom
>http://www.siriusit.co.uk
>t: +44 870 608 0063
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090717/81a7a2e7/attachment.html>
