[postgis-devel] problem with makefile in MinGW in trunk
nicklas.aven at jordogskog.no nicklas.aven at jordogskog.no
Fri Jul 17 04:28:37 PDT 2009
No, sorry.
The postgresql-PATH isn't there, is it?
2009-07-17 nicklas.aven at jordogskog.no wrote:
yes it is but with same corrupt PATH:> >make -C regress check
> /bin/sh.exe: line 0: pushd: c:/POSTGR~3/bin: No such file or directory
> make[1]: Entering directory `/c/thesrc/pg15_ny/regress'
> sed 's,$libdir/postgis,/c/thesrc/pg15_ny/regress/../postgis/libpostgis,g' ../postgis/postgis.sql > postgis.sql
> echo ":.:/usr/local/bin:/mingw/bin:/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem:/c/Programfiler/Hewlett-Packard/IAM/bin:/c/Programfiler/Windows Imaging/:/c/WINDOWS/system32/WindowsPowerShell/v1.0:/mingw/bin:/c/Programfiler/Microsoft SQL Server/100/Tools/Binn/:/c/Programfiler/Microsoft SQL Server/100/DTS/Binn/:/c/Programfiler/Microsoft SQL Server/100/Tools/Binn/VSShell/Common7/IDE/:/c/Programfiler/TortoiseSVN/bin:/c/strawberry/c/bin:/c/strawberry/perl/bin"
> ./run_test: line 386: psql: command not found
> Creating spatial db postgis_reg
> ./run_test: line 393: createdb: command not found
> ./run_test: line 394: createlang: command not found
> ./run_test: line 413: psql: command not found> Something went wrong (no postgis installed in postgis_reg).
>  For details, check /tmp/pgis_reg_5928/regress_log
> >> it returned:
> >> PATH=.:/usr/local/bin:/mingw/bin:/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem:/c/Programfiler/Hewlett-Packard/IAM/bin:/c/Programfiler/Windows
> >> PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PSC1
> >> PYTHONPATH=C:\Programfiler\ArcGIS\bin
> >> PKG_CONFIG_PATH=/mingw/lib/pkgconfig
> >That looks okay. Please try the attached regress/Makefile and see what
> >TESTPATH looks like. It should be the same as above, except with the
> >path to your PostgreSQL bin directory prepended.
> >ATB,
> >Mark.
> >Mark Cave-Ayland - Senior Technical Architect
> >PostgreSQL - PostGIS
> >Sirius Corporation plc - control through freedom
> >www.siriusit.co.uk
> >t: +44 870 608 0063
> >_______________________________________________
> >postgis-devel mailing list
> >postgis-devel at postgis.refractions.net
> >postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090717/1952e7f4/attachment.html>
