[postgis-devel] [PostGIS] #129: Test 1.4 against Windows
PostGIS trac at osgeo.org
Fri Jul 17 07:36:39 PDT 2009
  Reporter:  pramsey   |       Owner:  mcayland
      Type:  task      |      Status:  assigned
  Priority:  medium    |   Milestone:  postgis 1.4.0
 Component:  postgis   |     Version:  1.4
Resolution:  accepted  |    Keywords:
Comment (by robe):
 Mark,
 It fails for us on the loader, but I think there is something wrong with
 our libiconv2 install since it keeps complaining about not being able to
 find it.  I tested on my messy isntall which doesn't complain about
 libiconv, and it gives similar errors too.  Is this what you were talking
 about to confirm.
 TMPDIR is /tmp/pgis_reg_308
 PATH is
 "c:/POSTGRES84//bin":/c/postgres84/bin:.:/usr/local/bin:/mingw/bin:/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem:/c/Program
 Files/GnuWin32/bin:/mi
 n
  PostgreSQL 8.4.0 on i686-pc-mingw32, compiled by GCC gcc.exe (GCC) 3.4.5
 (mingw-vista special r3), 32-bit
  Postgis 1.4.0rc2 - 2009-07-17 13:55:37
    GEOS: 3.1.1-CAPI-1.6.0
    PROJ: Rel. 4.6.1, 21 August 2008
 Running tests
  loader/Point. failed (running shp2pgsql: /tmp/pgis_reg_308/loader.err)
  loader/PointM. failed (running shp2pgsql: /tmp/pgis_reg_308/loader.err)
  loader/PointZ. failed (running shp2pgsql: /tmp/pgis_reg_308/loader.err)
  loader/MultiPoint. failed (running shp2pgsql:
  loader/MultiPointM. failed (running shp2pgsql:
  loader/MultiPointZ. failed (running shp2pgsql:
  loader/Arc. failed (running shp2pgsql: /tmp/pgis_reg_308/loader.err)
  loader/ArcM. failed (running shp2pgsql: /tmp/pgis_reg_308/loader.err)
  loader/ArcZ. failed (running shp2pgsql: /tmp/pgis_reg_308/loader.err)
  loader/Polygon. failed (running shp2pgsql: /tmp/pgis_reg_308/loader.err)
  loader/PolygonM. failed (running shp2pgsql: /tmp/pgis_reg_308/loader.err)
  loader/PolygonZ. failed (running shp2pgsql: /tmp/pgis_reg_308/loader.err)
  regress. failed (diff expected obtained: /tmp/pgis_reg_308/test_13_diff)
  regress_index. ok
  regress_index_nulls. ok
  lwgeom_regress. ok
  regress_lrs. ok
  removepoint. ok
  setpoint. ok
  simplify. ok
  snaptogrid. ok
  affine. ok
  wkt. failed (diff expected obtained: /tmp/pgis_reg_308/test_23_diff)
  measures. ok
  long_xact. ok
  ctors. ok
  sql-mm-serialize. ok
  sql-mm-circularstring. ok
  sql-mm-compoundcurve. ok
  sql-mm-curvepoly. ok
  sql-mm-general. ok
  sql-mm-multicurve. ok
  sql-mm-multisurface. ok
  geojson. ok
  gml. ok
  svg. ok
  kml. ok
  regress_ogc. failed (diff expected obtained:
 /tmp/pgis_reg_308/test_38_diff)
  regress_bdpoly. ok
  regress_proj. ok
  regress_ogc_cover. ok
  regress_ogc_prep. ok
 Run tests: 42
 Failed: 15
 make[1]: Leaving directory `/c/thesrc/postgis-1.4.0rc2/regress'
Ticket URL: <http://trac.osgeo.org/postgis/ticket/129#comment:10>
