[postgis-devel] [PostGIS] #129: Test 1.4 against Windows
PostGIS trac at osgeo.org
Fri Jul 17 12:25:03 PDT 2009
  Reporter:  pramsey   |       Owner:  mcayland
      Type:  task      |      Status:  assigned
  Priority:  medium    |   Milestone:  postgis 1.4.0
 Component:  postgis   |     Version:  1.4
Resolution:  accepted  |    Keywords:
Comment (by robe):
 Mark we tested on our new install again.  There is nothing wrong with our
 libiconv.  The problem seems to be that the loader files can't see it.
 If we copy the libpq.dll and libiconv-2.dll that we compiled into the
 loader folder.  The error goes away.
 This is what our test looks like now against PostgreSQL 8.4.0
  PostgreSQL 8.4.0 on i686-pc-mingw32, compiled by GCC gcc.exe (GCC) 3.4.5
 (mingw-vista special r3), 32-bit
  Postgis 1.4.0rc2 - 2009-07-17 13:55:37
    GEOS: 3.1.1-CAPI-1.6.0
    PROJ: Rel. 4.6.1, 21 August 2008
 Running tests
  loader/Point.............. ok
  loader/PointM.............. ok
  loader/PointZ.............. ok
  loader/MultiPoint.............. ok
  loader/MultiPointM.............. ok
  loader/MultiPointZ.............. ok
  loader/Arc.............. ok
  loader/ArcM.............. ok
  loader/ArcZ.......... ok
  loader/Polygon.............. ok
  loader/PolygonM.............. ok
  loader/PolygonZ.............. ok
  regress. failed (diff expected obtained: /tmp/pgis_reg_692/test_13_diff)
  regress_index. ok
  regress_index_nulls. ok
  lwgeom_regress. ok
  regress_lrs. ok
  removepoint. ok
  setpoint. ok
  simplify. ok
  snaptogrid. ok
  affine. ok
  wkt. failed (diff expected obtained: /tmp/pgis_reg_692/test_23_diff)
  measures. ok
  long_xact. ok
  ctors. ok
  sql-mm-serialize. ok
  sql-mm-circularstring. ok
  sql-mm-compoundcurve. ok
  sql-mm-curvepoly. ok
  sql-mm-general. ok
  sql-mm-multicurve. ok
  sql-mm-multisurface. ok
  geojson. ok
  gml. ok
  svg. ok
  kml. ok
  regress_ogc. failed (diff expected obtained:
 /tmp/pgis_reg_692/test_38_diff)
  regress_bdpoly. ok
  regress_proj. ok
  regress_ogc_cover. ok
  regress_ogc_prep. ok
 Run tests: 42
 Failed: 3
 I'll attach the diff files in a bit.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/129#comment:15>
