[postgis-devel] Vote for 1.4 Release
Kevin Neufeld kneufeld at refractions.net
Wed Jul 22 14:00:10 PDT 2009
K, well, since everyone else can get it working then I must be doing something wierd cuz I can't get the regression to
actually run.  I can get PostGIS installed and working just fine ... I just can't get the regression suite to run.
I don't see any issues when using a similar script against the 1.3 branch.
Attached is a script and results I get when trying to run regression against an empty 8.2.13 install. (error occurs in
line 326 in log file) pg_config is not found.
If you're convinced it's just me, then I vote +1 as well.
-- Kevin
Kevin Neufeld wrote:
> I'm just running regression now.  At first glance, I don't get the same
> errors as with trunk when running postgis.sql, but I am getting the same
> make regress errors.
> Looking a little more into this now.
> -- Kevin
> Paragon Corporation wrote:
>> Good.  So we are just waiting for Kevin since Mark has already giving his
>> blessing.
>> -----Original Message-----
>> From: postgis-devel-bounces at postgis.refractions.net
>> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
>> Ramsey
>> Sent: Wednesday, July 22, 2009 3:09 PM
>> To: PostGIS Development Discussion
>> Subject: Re: [postgis-devel] Vote for 1.4 Release
>> Nope, I vote +1, I'd rather have a release out than not. And the
>> volume of
>> bug reports will help us determine what stupid regression mistakes we
>> have
>> left in place and whether they are important.
>> P.
>> On Wed, Jul 22, 2009 at 12:01 PM, Paragon Corporation<lr at pcorp.us> wrote:
>>> Paul,
>>> No.  We had pushed that to 1.4.1
>>> http://trac.osgeo.org/postgis/ticket/222
>>> This is beginning to sound like a
>>> "But, we have waited for so long why don't we put the icing on the
>>> cake and wait for the GUI to compile under windows?"
>>> If you are thinking that then we should probably have an RC3 and take
>>> care of the upgrade issue I mentioned here
>>> http://trac.osgeo.org/postgis/ticket/223
>>> I'm pretty sure our upgrade script is missing the box3d_extents
>>> autocasts.
>>> I also feel we should make the box3d_extent --> box2d CAST explicit
>>> instead of implicit.
>>> I believe that is the CAST that is causing me problems when I restore
>>> a 1.3 db unto  a fresh 1.4 db and I question its value since I think
>>> most of our functions Have casts for box3d.  That I haven't tested
>>> though.
>>>  Thanks,
>>> Regina
>>> Paul Ramsey
>>> Sent: Wednesday, July 22, 2009 1:01 PM
>>> Does the GUI build?
>>> On Wed, Jul 22, 2009 at 9:26 AM, Paragon Corporation<lr at pcorp.us> wrote:
>>>>  We have successfully make checked under windows for 8.2,8.3,8.4
>>>>  Can we have a 1.4 release
>>>>  +1
>>>> Thanks,
>>>> Regina
>>>> _______________________________________________
>>>> postgis-devel mailing list
>>>> postgis-devel at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090722/0049ec40/attachment.ksh>
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090722/0049ec40/attachment-0001.ksh>
