[postgis-devel] Vote for 1.4 Release
Paragon Corporation lr at pcorp.us
Wed Jul 22 14:15:26 PDT 2009
Kevin,
Given that these are the kind of errors we were getting on windows earlier,
I am a little concerned.
Paul -- does it still work for you on Mac OSX.  I can test my other OpenSUSE
box, which is running Pg 8.3 I think.
Like I said, the OpenSUSE I tested this morning was running 8.2.something,
but I did have to do an sh autogen.sh (I think I got similar errors before I
did that).
Looks like you did that though.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Kevin
Neufeld
Sent: Wednesday, July 22, 2009 5:00 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Vote for 1.4 Release
K, well, since everyone else can get it working then I must be doing
something wierd cuz I can't get the regression to actually run.  I can get
PostGIS installed and working just fine ... I just can't get the regression
suite to run.
I don't see any issues when using a similar script against the 1.3 branch.
Attached is a script and results I get when trying to run regression against
an empty 8.2.13 install. (error occurs in line 326 in log file) pg_config is
not found.
If you're convinced it's just me, then I vote +1 as well.
-- Kevin
Kevin Neufeld wrote:
> I'm just running regression now.  At first glance, I don't get the
> same errors as with trunk when running postgis.sql, but I am getting
> the same make regress errors.
> Looking a little more into this now.
> -- Kevin
> Paragon Corporation wrote:
>> Good.  So we are just waiting for Kevin since Mark has already giving
>> his blessing.
>> Paul Ramsey
>> Sent: Wednesday, July 22, 2009 3:09 PM
>> Nope, I vote +1, I'd rather have a release out than not. And the
>> volume of bug reports will help us determine what stupid regression
>> mistakes we have left in place and whether they are important.
>> P.
>> On Wed, Jul 22, 2009 at 12:01 PM, Paragon Corporation<lr at pcorp.us> wrote:
>>> Paul,
>>> No.  We had pushed that to 1.4.1
>>> http://trac.osgeo.org/postgis/ticket/222
>>> This is beginning to sound like a
>>> "But, we have waited for so long why don't we put the icing on the
>>> cake and wait for the GUI to compile under windows?"
>>> If you are thinking that then we should probably have an RC3 and take
>>> care of the upgrade issue I mentioned here
>>> http://trac.osgeo.org/postgis/ticket/223
>>> I'm pretty sure our upgrade script is missing the box3d_extents
>>> autocasts.
>>> I also feel we should make the box3d_extent --> box2d CAST explicit
>>> instead of implicit.
>>> I believe that is the CAST that is causing me problems when I restore
>>> a 1.3 db unto  a fresh 1.4 db and I question its value since I think
>>> most of our functions Have casts for box3d.  That I haven't tested
>>> though.
>>>  Thanks,
>>> Regina
>>> Paul Ramsey
>>> Sent: Wednesday, July 22, 2009 1:01 PM
>>> Does the GUI build?
>>> On Wed, Jul 22, 2009 at 9:26 AM, Paragon Corporation<lr at pcorp.us> wrote:
>>>>  We have successfully make checked under windows for 8.2,8.3,8.4
>>>>  Can we have a 1.4 release
>>>>  +1
>>>> Thanks,
>>>> Regina
>>>> _______________________________________________
>>>> postgis-devel mailing list
>>>> postgis-devel at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
