[postgis-devel] Typmod Again
Paul Ramsey pramsey at cleverelephant.ca
Wed Jul 22 17:04:08 PDT 2009
32 bits:
Top 24 bits for SRID,
Middle 6 bits for Type,
Bottom 2 bits for Z/M flags.
The difficulty is not doing typmod, it's doing it without breaking
backwards compatibility. I'm also currently running into some oddness
with PgSQL not handing me the typmod in the _in function (which is
required to enforce the restriction), even though one is defined on
the column.
There's some issues in general with typmod, I fear, which is that a
typmod is not a constraint. Where is it enforced? It seems like only
in the _in function, which just protects the on inserts from text.
If I do
UPDATE mytable SET thegeom = ST_SetSRID(thegeom, 1111)
and 1111 is not my SRID typmod, what happens?
P.
On Wed, Jul 22, 2009 at 4:50 PM, Stephen Frost<sfrost at snowman.net> wrote:
> Paul,
> * Paul Ramsey (pramsey at opengeo.org) wrote:
>> FYI, I'm implementing this stuff within the context of GEOGRAPHY,
>> which allows us to sort of play with these ideas before rolling them
>> onto GEOMETRY in a breaking way. I do think that trying to hew closer
>> to the standards base for GEOMETRY when we do the 2.0 release would be
>> a good idea, try to put all the breaking changes we can think of into
>> one release.
> I've been meaning to work on the typmod stuff for quite some time, but
> have just been way too busy. :/
> What's your implementation plan?  Will you be using a side-table for
> each distinct typmod used in the system, or trying to encode the full
> typmod into an integer?  If the dimension can be derived from the type,
> it might be entirely possible to fit the rest into an integer, provided
> an SRID isn't required to allow for a full integer itself.  I don't
> recall ever getting an answer to how big an SRID is allowed to be..
> Do you need help with it?  Is there a spec somewhere already that
> details your approach?
>        Thanks,
>                Stephen
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> iEYEARECAAYFAkpnpa8ACgkQrzgMPqB3kigLvwCfYzyhkjwnq8YQZx9zcwLd3zrX
> SAYAoJSLvluH5Ce3rWMRKG8ia7OPYXe2
> =IcJT
> -----END PGP SIGNATURE-----
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
