[postgis-devel] Typmod Again
Paul Ramsey pramsey at cleverelephant.ca
Thu Jul 23 06:49:15 PDT 2009
That's already caught at the type level. "GEOMETRY" is planar,
"GEOGRPAHY" are geodetic. So we don't need to use typmod space for
that.
P
On Thu, Jul 23, 2009 at 12:06 AM, Olivier
Courtin<olivier.courtin at gmail.com> wrote:
> Hi,
>> Bloody heck, you're right... the best laid plans... well, I could
>> squeeze type down to 5 bits (32 possibilities) or srid down to 23 bits
>> (8388608 possibilities). Any preferences? (We currently only use 4
>> bits for type, so this still an improvement, and official EPSG codes
>> still don't exceed 65536.)
> 17 differentes types are defined in current SQL/MM spec,
> so 5 bits should be enough
> On the other hand, could we add a bit to be able to do the difference between
> planar metric geometries and geocentrics ones ?
> Could be realy usefull...
> Olivier
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
