[postgis-devel] Adding out-db rasters support to gdal2wktraster
Mateusz Loskot mateusz at loskot.net
Mon Jul 27 07:55:33 PDT 2009
Jorge Arévalo wrote:
 > I've been working on a TODO task of gdal2wktraster script. The support
 > for out-db rasters. My point is to create a blank tiff raster and fill
 > it with the bands of the original one. The name of the new raster is
 > automatically generated based on the name of the original file.
OK
 > It should be necessary to add a path before the name of the file in
 > hexwkb string. I'm sure there are more errors. For this reason, I send
 > my version to the community, and specially to Mateusz. I'll be really
 > pleased to know my errors, and if this code helps.
It would be better if you could generate patch with your changes against
the version of gdal2wktraster from Subversion repository and submit it
as ticket with patch attached.
http://trac.osgeo.org/postgis/
This is one of the most efficient ways to submit a code and ask for review.
See example of such ticket.
http://trac.osgeo.org/geos/ticket/278
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
