[postgis-devel] New uninstall_postgis.sql script
Paragon Corporation lr at pcorp.us
Sat Jun 6 11:37:24 PDT 2009
I think the other issue with types is that we were going to rename all the
helper functions use  st_geometry_in to postgis_geometry_in etc.
But we can do an ALTER FUNCTION st_geometry_in to postgis_geometry_in or
something like that to solve that little problem I would think.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Saturday, June 06, 2009 2:26 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] New uninstall_postgis.sql script
Tom Lane wrote:
> CREATE OR REPLACE what?  It seems unlikely that you need to change the
> names of the I/O functions, and you can't change the type's
> representational properties if you're hoping to do upgrade-in-place.
> So I'm not really seeing what CREATE OR REPLACE TYPE would buy exactly.
> Replacing the .so doesn't seem to be a problem, so long as you avoided
> putting any version numbers into the .so name referenced in the SQL
> function definitions.
Well we don't use the old PostgreSQL mechanism where the library contains
the major/minor numbers with a symlink; however with 1.4 the resulting
library file is named "postgis-1.4.so" or similar. The reason for this is
that 1.4 is sufficiently different under the hood for it to be extremely
useful to have different versions of PostGIS installed in different
databases within the same cluster for testing.
I think there are two cases here: the first is the 8.3 -> 8.4 migration
using the same 1.3 version of PostGIS which won't be a problem. The second
case is trying to upgrade from 8.3 with PostGIS 1.3 to 8.4 with PostGIS 1.4
at the same time which is the one most likely to break, especially as we
have seen in the wild that due to neglect within the upgrade script, many
upgrades have not been 100% successful in the past.
But we need to treat these as two distinct cases.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect PostgreSQL - PostGIS Sirius
Corporation plc - control through freedom http://www.siriusit.co.uk
t: +44 870 608 0063
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
