[postgis-devel] Re: [PostGIS] #190: populate_geometry_columns gives nonstandard use of \' in a string literal
PostGIS trac at osgeo.org
Sun Jun 7 20:58:32 PDT 2009
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  new
  Priority:  low      |   Milestone:  postgis 1.4.1
 Component:  postgis  |     Version:  1.4
Resolution:           |    Keywords:
Comment (by kneufeld):
 Sorry, I didn't see this ticket.
 robe, I'm not sure I understand the problem.  Can you please provide an
 example?  I don't get the warning.
 WRT the other comment about geometry type enforcement, the function
 detects the geometry type/srid/dimension by looking at the first geometry
 in the table and then tries to add the appropriate constraint to the
 column.  These are the same constraints that would have been added had you
 used AddGeometryColumn().  Are you saying that you are trying to mix
 geometry types in the same column?  I don't think that's a standard use of
 PostGIS.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/190#comment:2>
