[postgis-devel] Re: [PostGIS] #190: populate_geometry_columns gives nonstandard use of \' in a string literal
PostGIS trac at osgeo.org
Sun Jun 7 21:28:06 PDT 2009
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  new
  Priority:  low      |   Milestone:  postgis 1.4.1
 Component:  postgis  |     Version:  1.4
Resolution:           |    Keywords:
Comment (by robe):
 Kevin,
 if its any help.  It appears to be the RAISE WARNINGs you have in
 populate_geometry_columns(oid) that are at fault.  Strange I didn't even
 know those got flagged by this escape thing.  Always thought those were
 limited to sql statements.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/190#comment:4>
