[postgis-devel] Re: [PostGIS] #167: shp2pgsql double frees on medford buildings.shp
PostGIS trac at osgeo.org
Mon Jun 8 14:13:12 PDT 2009
  Reporter:  pramsey  |       Owner:  pramsey
      Type:  defect   |      Status:  new
  Priority:  high     |   Milestone:  postgis 1.4.0
 Component:  postgis  |     Version:  1.4
Resolution:           |    Keywords:
Comment (by pramsey):
 It actually still double-frees, at r4153. I will see if I can make a terse
 example. The difficulty of working around these issues (I am going to load
 the file into 1.3, find the bad row, export that, then attach it) speaks
 to my worries about doing validity checking on load, even relatively
 trivial validity checking (closed rings, etc). Because fixing bad things
 requires a tool, and PostGIS is the tool that, presumably, a PostGIS user
 would like to use.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/167#comment:6>
