[postgis-devel] RFC3
Paragon Corporation lr at pcorp.us
Wed Jun 10 04:17:28 PDT 2009
+ 0.5
I guess my concern is mostly upgrade.  Are you planning to do this for 1.4?
I guess as far as upgrade concerns and maybe you have thought about this
already.  Isn't it going to be difficult to get rid of things like
st_geometry_overlap
If they are used in operator definitions.
I would prefer if these were marked RENAME to and for UPGRADE we would use a
RENAME, but that doesn't seem to be an option since we have the renamed
names already present (UNLESS we use totally different names).
Makes me wonder if we should have a plpgsql function as part of UPGRADE as
it would vary depending on how people were upgrading in the past if these
operator functions we are dropping are or are not in use so we'd need to put
in a lot of conditional checks like if in use in OPERATORS RENAME them and
if not drop them.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Wednesday, June 10, 2009 4:56 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] RFC3
Paul Ramsey wrote:
> I'd like to bring this to a vote. I have not touched the naming of
> longxact functions on purpose, because I think that's a separate
> discussion. I'm willing to have that discussion, but I don't want it
> to stop doing the RFC3 change.
> http://trac.osgeo.org/postgis/ticket/195
The only thing I noticed was the name of the GiST functions, e.g.
postgis_gist_compress(). Given that we hope to have a geography type at some
point, perhaps we should consider postgis_gist_geometry_compress() etc...
Other than that, +1 from me as it makes things seem a lot tidier.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect PostgreSQL - PostGIS Sirius
Corporation plc - control through freedom http://www.siriusit.co.uk
t: +44 870 608 0063
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
