[postgis-devel] Re: [PostGIS] #156: ST_AsEWKT and ST_AsText crashes with some invalid geometries
PostGIS trac at osgeo.org
Thu Jun 11 05:55:10 PDT 2009
  Reporter:  robe     |       Owner:  mcayland
      Type:  defect   |      Status:  reopened
  Priority:  high     |   Milestone:  postgis 1.4.0
 Component:  postgis  |     Version:  1.4
Resolution:           |    Keywords:
Changes (by robe):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 Mark,
 This is not completely fixed.  I can do the above now on the latest
 Postgis 1.4 build, however if I do the below -- backend crashes (but the
 same exercise works fine in 1.3)
 SELECT
 CAST('0106000000010000000103000000010000000700000024213D12AA7BFD40945FF42576511941676A32F9017BFD40B1D67BEA7E511941C3E3C640DB7DFD4026CE38F4EE531941C91289C5A7EFD40017B8518E3531941646F1599AB7DFD409627F1F0AE521941355EBA49547CFD407B14AEC74652194123213D12AA7BFD40945FF42576511941'
 As geometry);
Ticket URL: <http://trac.osgeo.org/postgis/ticket/156#comment:5>
