[postgis-devel] [PostGIS] #129: Test 1.4 against Windows
PostGIS trac at osgeo.org
Fri Jun 12 04:31:10 PDT 2009
  Reporter:  pramsey   |       Owner:  mcayland
      Type:  task      |      Status:  assigned
  Priority:  medium    |   Milestone:  postgis 1.4.0
 Component:  postgis   |     Version:  1.4
Resolution:  accepted  |    Keywords:
Comment (by robe):
 Yap it manages to create the postgis_reg db. pgpllang language exists too,
 though that may be defaulted in 8.4 so might not mean it created it and
 then it promptly kills the backend.  There are so many variables that
 changed -- all 3 (geos, Paul doing his cleanup, and me running make check
 for first time) , so I'm going to isolate it unless you are seeing the
 same thing.
 Anyrate seems to be the make check process rather than anything wrong with
 the install since I can run spatial queries fine.  Maybe its a weird
 character or something that windows doesn't like.  I also have not
 retested on my OpenSUSE boxes.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/129#comment:5>
