[postgis-devel] [PostGIS] #129: Test 1.4 against Windows
PostGIS trac at osgeo.org
Mon Jun 15 08:41:36 PDT 2009
  Reporter:  pramsey   |       Owner:  mcayland
      Type:  task      |      Status:  assigned
  Priority:  medium    |   Milestone:  postgis 1.4.0
 Component:  postgis   |     Version:  1.4
Resolution:  accepted  |    Keywords:
Comment (by robe):
 Mark -- any chance you can do a quick make check on yours. I don't have
 8.3 loaded on here to verify if make check works on that and probably
 won't be able to get to that for a couple days.
 Paul -- if you really want to push out an RC, I'm all for it.  Don't let
 this get in your way.  Like I said this is the first time I attempted a
 make check under MingW and I've been running a bunch of tests of 8.4 with
 GEOS 3.1.1 (ming compiled) and some on real data.  As far as I can tell it
 performs fine.  Perhaps if you call it a beta instead of an RC you'll feel
 better :).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/129#comment:7>
