[postgis-devel] [PostGIS] #198: shp2pgsql gives bad output on bad input
PostGIS trac at osgeo.org
Mon Jun 15 10:27:57 PDT 2009
  Reporter:  pramsey  |       Owner:  mcayland
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  postgis 1.4.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Old description:
> Using the building_oops data from #167, you get I get the following
> output:
> Heron-2:buildings_oops pramsey$ shp2pgsql buildings_oops.shp b
> Shapefile type: PolygonZ
> Postgis type: MULTIPOLYGON[4]
> SET STANDARD_CONFORMING_STRINGS TO ON;
> BEGIN;
> CREATE TABLE "b" (gid serial PRIMARY KEY,
> "layer" varchar(254),
> "elevation" numeric,
> "shape_leng" numeric,
> "shape_area" numeric);
> SELECT AddGeometryColumn('','b','the_geom','-1','MULTIPOLYGON',4);
> ERROR: geometry requires more points
> INSERT INTO "b" ("layer","elevation","shape_leng","shape_area",the_geom)
> VALUES
> ('S-BUILDING','1384.22300000','0.00000000000','0.00000000000',Heron-2:buildings_oops
> pramsey$
> Again, I re-iterate, that we should not be doing validity checking in the
> loader.
New description:
 Using the building_oops data from #167, I get the following output:
 BEGIN;
 VALUES
 pramsey$
 loader.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/198#comment:2>
