[postgis-devel] [PostGIS] #202: upgrade issues
PostGIS trac at osgeo.org
Thu Jun 18 09:09:44 PDT 2009
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  postgis 1.4.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment (by robe):
 FYI my prior problem was a false alarm.  I dumped and reloaded using the
 PostgreSQL 8.4 dump reload and it worked fine this time after upgrading
 (and my indexes were intact).  So maybe I had used 8.2 to dump before or
 something.  Anyrate not sure whatever was amiss before but upgrade seems
 to work well as far as I can tell.  Except for the aggregate issue (when
 you use aggs in views).  Have to drop the view first before you can
 upgrade.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/202#comment:15>
