[postgis-devel] ST_OrderingEquals vs ~=
Paragon Corporation lr at pcorp.us
Sat Jun 20 20:25:35 PDT 2009
You sure it doesn't.  If it doesn't then our documentation is wrong
http://postgis.refractions.net/documentation/manual-svn/ST_Geometry_Same.htm
l
Also I thought it did because when I do this
SELECT * FROM
tbl_feature_data WHERE the_geom ~=
'0101000020E610000009D31947329B5DC059448510E3A84240'
I see my spatial indexes being used.
Also when I look in the definition for gist_geometry_ops, I see it listed
CREATE OPERATOR CLASS gist_geometry_ops DEFAULT
   FOR TYPE geometry USING gist AS
   FUNCTION 1  lwgeom_gist_consistent(internal, geometry, integer),
   FUNCTION 2  lwgeom_gist_union(bytea, internal),
   FUNCTION 3  lwgeom_gist_compress(internal),
   FUNCTION 4  lwgeom_gist_decompress(internal),
   FUNCTION 5  lwgeom_gist_penalty(internal, internal, internal),
   FUNCTION 6  lwgeom_gist_picksplit(internal, internal),
   FUNCTION 7  lwgeom_gist_same(box2d, box2d, internal)
   STORAGE box2d;
 Yah the ST_Equals things was another open question that that should use an
index but doesn't.
The = behavior -- I think we had big long heated arguments about this though
can't quite remember what if anything we decided. I think it was a stand
still and everyone was either afraid to touch it because its such a long
standing gotcha and wasn't a big deal once you know abut it.  If we change
this, I suspect it may slow down a lot of things and I wasn't clear if the
reason for its existence was for performance or because it ironically
doesn't use a gist index and a non-gist based operator is needed for GROUP
BY, UNION since in theory it shouldn't be lossy though it is really lossy.
Do things like UNION, GROUP BY etc require btree based operators?  It is
very strange that the very thing you would think would use a gist index
(bbox = bbox) is not defined for gist but for btree. Or at least that always
kept me scratching my head.
The other side effects of changing this behavior
Pro - Leo and I have to rip out 2 pages from our book describing how to not
be a victim of the = is not = paradox (it keeps people awake)
Con - Leo and I will have to rip out 2 pages from our book describing how to
not be a victim of the = is not = paradox. (it makes PostGIS more logical
sounding)
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Kevin
Neufeld
Sent: Saturday, June 20, 2009 10:08 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] ST_OrderingEquals vs ~=
Actually, looking at it, I think this is correct.
~= does not use indexes.  The operator invokes 'ST_geometry_same' which
exposes the C function 'LWGEOM_same' found in 'lwgeom_functions_basic.c'.
Your other comment about ST_Equals could be looked at however.
It currently just calls geomequals, without making use of any indexes.
Shouldn't the function be a simply wrapper for 'SELECT $1 & $2 AND
_ST_Equals($1, $2)'?
Also, why is the = operator bound to lwgeom_eq and not LWGEOM_same?  The
former uses bounding boxes for comparison and the later compares exact
geometry equality.  I know that this operator is used in GROUP BY
expressions .. but would it be beneficial to GROUP BY the exact geometries
instead of just their bounding boxes? This is such a big PostGIS gotcha.
Anywho, just some thoughts.
-- Kevin
Paragon Corporation wrote:
> I think Kevin mentioned this before and he wasn't sure why either but
> thought I would bring it up since I'm not clear what the reason for this
is.
> Our ST_OrderingEquals function is a short-hand for SELECT $1 && $2 AND
> $1 ~= $2
> But ~= already uses a GIST index doesn't it?  So why this extra $1 &&
> $2 check?
> Is the && faster to compute? Or have higher selectivity?
> Thanks,
> Regina
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
