[postgis-devel] Specifying end cap and join styles Buffer op
strk strk at keybit.net
Sun Jun 21 15:11:33 PDT 2009
On Sun, Jun 21, 2009 at 11:02:37PM +0100, Mark Cave-Ayland wrote:
> String parsing seems quite horrible in this day and age; any reason we
> can't use PostgreSQL arrays to pass in the information instead? I really
> don't care too much about Oracle compatibility since PostGIS as a
> project is heading more towards SQL-MM.
Paul and me excercised a bit in inputing SQL and found arrays
being less comfortable than a plain string.
Compare:
	st_buffer(geom, 10, 'join=bevel endcap=flat limit=10');
with:
	st_buffer(geom, 10, '{{"join", bevel"},{"endcap","flat"},{"limit","10"}}');
(pretty sure the first one I typed it correctly, should check for the second)
--strk;
 Free GIS & Flash consultant/developer      ()  ASCII Ribbon Campaign
 http://foo.keybit.net/~strk/services.html  /\  Keep it simple!
