[postgis-devel] Specifying end cap and join styles Buffer op
Paul Ramsey pramsey at cleverelephant.ca
Mon Jun 22 11:48:43 PDT 2009
+1, also see my upcoming motion
On Mon, Jun 22, 2009 at 11:30 AM, strk <strk at keybit.net> wrote:
> On Mon, Jun 22, 2009 at 05:39:06AM -0400, Paragon Corporation wrote:
> > Strk,
> > I was thinking that we check it at the SQL  level.
> > So we would have say 3 functions
> > _ST_Buffer --> geom,rad,params  C lang calls postgis function directly
> > ST_Buffer(geom,rad,params) -> SELECT _ST_Buffer(geom,rad, CASE WHEN params
> > ~= '[0123456789]+' THEN 'quad_segments=' || params ELSE params END) ; (well
> > some regex thingy my syntax is probably wrong)
> > --I suppose in theory we don't need this last one anymore to keep backward
> > compatibility as the integer would be cast to text and move to the other
> > (which is perhaps what Paul was thinking in too terse of a statement),
> > -- but I don't like relying on the implicit cast being there.
> > ST_Buffer(geom,rad, quad_segment) (takes integer  -- which becomes
> > short-hand for something like _ST_Buffer(geom,rad, 'quad_segments=' ||
> > CAST(quad_segment As text))
> > So in the end you have just one C function to rule them all
> Alright, my +1 here.
> Can others with voting powers vote so I can proceed to speed ?
> TIA
> --strk;
>  Free GIS & Flash consultant/developer      ()  ASCII Ribbon Campaign
>  http://foo.keybit.net/~strk/services.html  /\  Keep it simple!
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
