[postgis-devel] PgAdmin III Plugins
Paul Ramsey pramsey at opengeo.org
Mon Jun 22 14:28:54 PDT 2009
Can we do this stuff on postgis-devel?
I think getting bundled in pgadmin is not very important, compared to
being bundled in the postgis windows stackbuilder build.
P.
On Jun 22, 2009, at 5:58 AM, Obe, Regina wrote:
> I was looking at the PgAdmin III 1.10 plugin architecture and as far
> as
> I can tell, it should be pretty easy to register the shp2pgsql-gui in
> there.
> The plugins menu is controlled by the file plugins.ini and you can
> register any executable in there.  I wonder if we can bribe them to
> include the shp2pgsql-gui as a preinstalled plugin so it appears
> along-side psql plugin. Both are compiled with gtk so I imagine it
> should be trivial.
> Well anyway once I have all this gtk, gtlib, pango stuff installed
> under
> my MingW, I'll attempt to register it as a plugin.
> Thanks,
> Regina
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
