[postgis-devel] [PostGIS] #209: Discrete Hausdorff distance implementation (through GEOS)
trac at osgeo.org
Wed Jun 24 08:17:08 PDT 2009
Reporter: vincentp | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version: trunk
Keywords: hausdorff distance geos |
JTS and GEOS have a discrete Hausdorff distance algorithm. It is currently
not exposed in GEOS C API, nor in PostGIS. A patch for GEOS is available
to expose these functions :
http://trac.osgeo.org/geos/ticket/264
Please find attached a patch to PostGIS trunk (at rev 4206) that
implements Hausdorff distance calculation using the GEOS C API provided by
this patch :
ST_HausdorffDistance(geometry, geometry)
and its variant with segment densification
ST_HausdorffDistance(geometry, geometry, float)
Documentation (from JTS) and unit test are included.
As the GEOS patch has still not been commited, you'll have to patch and
recompile geos to test it. The GEOS version test in postgis.sql.in.c are
made on GEOS 31 so as to be able to test. It should be changed to the GEOS
version patch #264 will be commited to.
This is my first patch for PostGIS, please be indulgent :)
I'll be waiting for a review to fix or improve the patch so that it can be
commited.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/209>
