[postgis-devel] postgis_upgrade.sql
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Wed Jun 24 09:21:55 PDT 2009
Kevin Neufeld wrote:
> I kinda agree.  Wouldn't we have to have an upgrade script for every
> permutation.
Well, not every permutation. We'd only agree to support certain
upgrades, say maybe 2 minor versions due to the limited testing
resource. So for 1.5 we'd just provide:
upgrade_1.3_to_1.5.sql
upgrade_1.4_to_1.5.sql
If in the future people wish to upgrade from say 1.3 to 1.6 then due to
the new versioning in 1.4 then they can go via an intermediate release
to get to the final version. A bit messy, but then at least someone with
expertise can keep the database consistent.
> What if instead of a one large plpgsql script, we were to wrap all the
> function/casts/type/etc declarations in their own plpgsql script that
> does a simple test and upgrades the function/type if needed.
> ie.
> CREATE OR REPLACE FUNCTION upgrade_function() RETURNS text AS
> DECLARE
>   postgisVersion text;
> BEGIN
>   postgisVersion := postgis_version();
>   IF (postgisVersion < '1.3') THEN
>     EXECUTE 'DROP FUNCTION deprecated_postgis_function';
>   END IF;
>   EXECUTE 'CREATE OR REPLACE ST_Box(box3d) ...';
>   RETURN 'done';
> END
> $$ LANGUAGE plpgsql;
> SELECT upgrade_function();
> DROP FUNCTION upgrade_function();
> I don't know, this seems quite unwieldy too.
> -- Kevin
No, I don't like this at all. The reason being that when fixing broken
upgrades manually, I often end up cutting and pasting various chunks out
of the generated update SQL script - and a change like this would make
it an almost impossible task :(
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
