[postgis-devel] [PostGIS] #209: Discrete Hausdorff distance implementation (through GEOS)
PostGIS trac at osgeo.org
Wed Jun 24 09:58:28 PDT 2009
  Reporter:  vincentp  |       Owner:  pramsey
      Type:  patch     |      Status:  new
  Priority:  medium    |   Milestone:  postgis 1.5.0
 Component:  postgis   |     Version:  trunk
Resolution:            |    Keywords:  hausdorff distance geos
Comment (by pramsey):
 I find this line in the patch confusing :)
 #if POSTGIS_GEOS_VERSION >= 31
 -- Requires GEOS >= 3.2.0
 Your comment correctly indicates your GEOS requirement, but your macro
 test does not. I think you'll want to fix all those macro tests.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/209#comment:2>
